73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: winningz on November 24, 2013, 10:36:25 pm
Title: Acceleration while in park or neutral.
Post by: winningz on November 24, 2013, 10:36:25 pm
My truck accelerates very high while in park or neutral. Once I put the truck into drive or reverse it goes back to normal. any suggestions?
Title: Re: Acceleration while in park or neutral.
Post by: bd on November 24, 2013, 11:47:08 pm
78 K10?  Which engine and trans?
What do you mean, your "truck accelerates very high while in park or neutral?"
Are you referring to idle RPM?  Is the engine cold or at operating temperature when this happens?  How high is "very high?"  1,600 RPM is the factory setting for cold fast idle speed with an automatic transmission.  Will the engine idle down if you quickly tap the accelerator pedal?
For reference, base idle at operating temperature should be 500 RPM in drive (roughly 700 RPM in park or neutral).  An idle solenoid, if you have one, should be adjusted to 600 RPM in drive whenever the solenoid is energized.
Post by: winningz on November 24, 2013, 11:56:54 pm
350 engine. My engine just sounds like someone is flooring it when it is in park or nuetral
Sent from my DROID RAZR using Tapatalk
Post by: winningz on November 24, 2013, 11:57:42 pm
Automatic transmission and yes a 78 k10
Post by: bd on November 25, 2013, 12:03:15 am
All the time, even when warm?
Is the throttle return spring broken (it should be a nested spring within a spring)?  Does it have cruise control?
Post by: winningz on November 25, 2013, 12:14:09 am
Does not have cc and it has just started doing it even when it is warm
Post by: bd on November 25, 2013, 12:46:19 am
Post by: winningz on November 25, 2013, 12:53:57 am
Thank you very much for all the help and replies. I noticed my throttle cable is too long after looking at my carb for a while. but that cant be the problem can it? I am not pushing on the gas while in park or neutral.
Post by: bd on November 25, 2013, 01:16:03 am
By design GM throttle cables are long enough to do one full roller coaster loop between the firewall and the mounting bracket on the intake.  The extra length prevents throttle surges as the engine moves in its rubber mounts.
Perform all the checks outlined previously, adding the following inspections to the list:
After you complete the list, post the results.
