73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: Ziptar on June 10, 2006, 08:39:00 am
Title: Rear coil over shocks for a 2WD??
Post by: Ziptar on June 10, 2006, 08:39:00 am
Can I get rear coil overs for a 2WD?? i am thinking a little extra capacity couldn't hurt.
Is the ride much harder with coil overs?
1979 Silverado C10 w/ Olds 5.7 Diesel
85 C10 Custom Deluxe
Title: Re: Rear coil over shocks for a 2WD??
Post by: 123 pugsy on June 14, 2006, 05:05:00 am
You can always add a leaf for extra capacity. Don't know about coil overs but beefing up springs will harden up the ride.
Post by: Ziptar on June 14, 2006, 06:15:00 am
Thanks, I swapping the 4 leafs for 6 leaf, didn't know if coilovers were availavle, figured they'd help.
Post by: roundedline on June 14, 2006, 12:45:00 pm
for extra load capacity leafs are a better option.  If you want a good ride AND more capacity you can add helper bags that you can inflate when heavier loads are in to level the truck back out.
www.airliftcompany.com/ridecontrol.htm
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Post by: VileZambonie on June 14, 2006, 05:23:00 pm
Leaf springs are progressive rate springs and most coil overs are constant rate springs too so really adding a leaf I agree is the best way to go
