73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: achevy1978 on December 29, 2013, 09:42:52 pm
can this th400 pump be resurfaced to remove the scoring??
tried to post picture but only will do 256kb...
hi guys
im am rebuilding (1st one) my th400. the forward and direct drums have the steel pistons with the spacers on top...if i wanted to add one or more frictions and steels to the 5 that are in there would i just take the 160 tho or so off the spacer?? is that how its done seeing the pistons can't be machined
thanks
Find an older transmission that uses aluminum pistons.
The steel pistons are not desirable for HD usage.
mines a 78... when did they start with the steel pistons ?? would a motor home or bread truck of the 70's have the aluminum ones? what was the cut off year of al pistons....and how would i know if it had them without taking it apart?
thanks
im rebuilding my th400 and wanted to get VESPEL and TEFLON RINGS
but they are listed for a 4l80e... are they the same as a th400?? will the center support,
pump and servo's all be the same rings
thanks
Various Resources:
- ATSG 400 Manual (https://www.atsg.us/atsg/gm-manuals-1/400.html) - a Must! Also available through Summit Racing, et al.
- How to Rebuild and Modify GM Turbo 400 Transmissions (http://www.summitracing.com/parts/sad-sa186/overview/) by Cliff Ruggles - an excellent reference!
- How to Build a High Performance TH400 (http://www.summitracing.com/parts/jpt-92077-t4d/overview/) DVD - moving pictures... :)
- Sonnax (http://www.sonnax.com) - problem solver upgrades
- Transtar Industries (http://www.transtar1.com/default.asp) - parts and references
- ATI Center Supports (http://www.summitracing.com/search/product-line/ati-th400-center-supports?tw=th400&sw=ATI%20TH400%20Center%20Supports)
