73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: Welshboy on October 13, 2006, 05:58:00 pm
Hi , I've just removed my sway bar and need to replace the bushings. Trouble is, they probably have not been removed for years and I can't push them or the metal sleeve out.
Anybody have any hints?
Thanks, Gawain
'78 Chevy K10, 6" lift
an air chisel will be your best bet
getthem pressed out at a machince shop costs a little but is the safeest way to go
Cut'em up, The replacements should include hardware.
I know this is old, but I have the same question. Does anyone have other ideas besides taking them to get pressed out? I was thinking of borrowing a vice or renting a ball joint press and trying to get that to work because both of those ideas are free. Ive been soaking them too.
burn them out with a torch
+1 for the gas wrench, even if it's just a little MAPP gas torch if you don't have access to oxy-acetylene. Second choice would be to mangle them with a sawzall and air hammer until they see things your way.
With a big enough C clamp, you can cut one side of the rubber off, and using a round piece of pipe that is the same size of the sway bar, you can make a home made press very easy. I did it with mine and worked very easy and did not take any time at all.
