73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: moregrip on January 04, 2014, 04:15:23 pm
Title: suspension fastners..........
Post by: moregrip on January 04, 2014, 04:15:23 pm
Need a few bolt sizes please.....example: 1/2"-13 x 3
1. the six bolts that secure the stock cross-member to the frame
2. the bolts that secure the angled metal piece(motor mount mounts to this) to the cross member and top of the frame
3. motor mount
4. bolts that shoot through the frame into the welded nuts on the cross member plate
5. Upper Ball joints
6. idler arm bracket
Title: Re: suspension fastners..........
Post by: bake74 on January 04, 2014, 08:32:33 pm
     To get an answer that can help you, we need your help first.
     Do not assume everyone can remember what vehicle you are talking about in each post, the year, make, model ( ie, 74 k10 ), and what you have if asking about specific item like size of your engine if asking about say different heads that you could use, should be included in your post if you are asking questions about your vehicle.
Post by: moregrip on January 04, 2014, 09:00:01 pm
73 Chevy C10 2wd 1/2ton pickup 250 inline 6
Post by: Irish_Alley on January 04, 2014, 11:11:21 pm
some of the parts you listed are supposed to be rivets. but you can replace them with bolts. and tell you the truth most time i have to grab a handful and try then to see what fits best. (helps to have a nut bin)
Post by: dvdswan on January 05, 2014, 11:10:15 am
don't go cheap, use grade 8 bolts.
Post by: Irish_Alley on January 07, 2014, 11:12:20 pm
8s are all we have in our shop.
Post by: moregrip on January 07, 2014, 11:31:07 pm
I was/am going with grade 8 or better. Was just hoping to get a few on order and delivered before I get back home. I'm active duty military so I only get back home for a few days at a stretch.
