can i put 3/4 ton springs on a 1/2 ton truck? my buddy's 85 gmc needs new front springs (broken leafs)and he wants to lift the front to match the rear. we THINK the rears are from a 3/4 ton as they have more leafs than my 1/2 ton does.there are 8 leafs on the rear axle. or did someone do some kind of cheap lift???? Edited by: bfofish at: 10/23/06 3:56 pm
are you talking about leafs from the front of a 3/4T truck? They should swap out. You could measure them for a comparison.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
yes the front leafs are broken so they need to be replaced. would they lift it as well? the rear of the truck sits about 2"-3" higher than the front. it looks like a hot rod that was jacked up with air shocks. Edited by: bfofish at: 10/23/06 4:01 pm
