73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => The Lows (Lowering/Drops) => Topic started by: OKUMA111 on October 27, 2006, 02:02:00 pm
Title: AIR BAG SET-UP HELP...
Post by: OKUMA111 on October 27, 2006, 02:02:00 pm
I NEED HELP ON INSTALLATION FOR A BAG SET-UP. RECOMENDATIONS ON BRANDS ARE WELCOME...... I PLAN TO DO THIS BY MID DECEMBER  YOUR HELP IS APPRECIATED.... I HAVE PLACED A LINK TO MY TRUCK.... HOPE U GUYS LIKE IT...   WWW.MYSPACE.COM/WICKED81GMC
Title: Re: AIR BAG SET-UP HELP...
Post by: shaved80 on October 29, 2006, 02:51:00 am
could you be a bit more specific? what do you want the bags for? ride quality? to lay out? just to get a few inches lower than static? bolt ons, weld ins?
Post by: OKUMA111 on October 29, 2006, 06:05:00 am
I WANT TO LAY LO BUT NOT LAY FRAME. NO HOPPING EITHER. JUST FOR SUNDAY CRUISING. BOLT ON OR WELD IN DOES NOT MATTER. <p></p><i></i>
Post by: shaved80 on October 31, 2006, 10:41:00 am
then what do you plan to lay? and are you going to be switch happy?
Post by: lowc10 on October 31, 2006, 10:46:00 pm
haha he said no hopping.....kinda kills hitting switches
if you don't want wide rear tires you can do all bolt on kits. do you want alot of lift out of it?
Post by: OKUMA111 on November 01, 2006, 11:26:00 pm
JUST LAY LOW .... I HAVE 22 X 9'S. NOT REALLY WIDE, I THINK.I'M MORE INTERESTED IN GOING LOW AND RIDABLE ----" HOW HIGH - I DONT CARE "
Post by: roundedline on November 02, 2006, 01:58:00 pm
If you want to ride low, I suggest either building your own setup, or if you want to go with a company, AirRide is who I would recommend.
Front:        use F6873 bags, make an upper plate bracket and lower cup, or AirRide ARF11800
Rear: flip the rear axle, remove all but 2 leafs and run some F9000 bags in front for a good ride. or AirRide PN ARK3002
For one done that way check out my best friends pickup (N2TRUX here):
www.imagestation.com/albu...4290400437
It is the Black 77 seen in the magazines.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Post by: lowc10 on November 02, 2006, 09:28:00 pm
getting real low on some 22's will take lots of cutting, and if you lay out i think you have to do something with the hood hinges
Post by: shaved80 on November 03, 2006, 12:33:00 am
i will lay doors on 22's with no problems as far as the hood hinges go
