73-87 Chevy _ GMC Trucks => Performance => Topic started by: kuhio on January 22, 2014, 10:31:58 am
Title: TBI to Vortec Heads Conversion Question <Stumped!!>
Post by: kuhio on January 22, 2014, 10:31:58 am
Ok, just had a 5.7L TBI 350 motor built for my 87 4x4 P/U upgraded to vortec heads, yanked out the old motor and I'm in the process of mocking everything up while the new motor is on the engine stand. ??? ....I didn't realize the modifications required switching from the stock TBI intake manifold, in my case an Edelbrock 3704 to the GMPP TBI vortec intake manifold! The old throttle body brackets don't fit, the egr/smog tubing/tubes needs to be reconfig and rerouted, AND NOW I CAN'T RIG UP THE A/C BRACKETS FOR THE COMPRESSOR!!!!!!
So far this is the only thing left that I can see during the mock up I'm gonna have to do some brain stormin on! The stock TBI intake manifold was of the 12 bolt variety and the new GMPP vortec intake manifold utilizes 8 bolts. My question is this, since the stock intake manifold bolts into the stock heads at a 23deg angle and the GMPP intake manifold bolts vertically into the vortec heads, the two bolts above the #1 cylinder will NOT line up and accept the small bracket for the A/C compressor!! This is the small bracket in which the larger A/C overhead bracket attaches to in order to assist in stabilizing the compressor and keep the belt tension tight. I am guessing I'll need to fabricate/jerry rig another bracket....yes, no? Has anyone here tackle this issue or have any suggestions?
Hopefully I explained everything in detail on what the heck I'm talking about, cuz I don't, just kidding :o ....I'll post some pics so you can visually view my dilemma.
Thanks in advance for steering me in the right direction..... ;D ;D
Title: Re: TBI to Vortec Heads Conversion Question <Stumped!!>
Post by: kuhio on January 22, 2014, 08:40:07 pm
Was just wondering, has anyone here converted to an all serpentine setup for an 87 with the R4 ac compressor at the current 2 o'clock position on the drivers side <inboard setup>? Or do they make such an animal, like maybe March Performance?
Thinking out loud.....
Post by: mike357 on February 17, 2014, 12:19:32 am
I put a serpentine system from a later model truck on my demon possessed '77.  It had the compressor on the passenger side. It will work with your setup because it can be independent of the intake. Originally it had two supports going to the intake, but I was able to make it work without them.
If you do this you will need to use a water pump from the same year as the donor truck. It rotates backwards.
 As far has getting one that has the compressor on the driver's side you would have to go 96' up, but it is a different compressor.
