73-87 Chevy _ GMC Trucks => Interior & Equipment => Topic started by: deveny7 on February 01, 2014, 08:58:00 pm
Title: Gauges/ Speedo cable install
Post by: deveny7 on February 01, 2014, 08:58:00 pm
Need advice on my '73 K10 gauges. Pulled the unit and circuit board looked rough but well connected. Tightened down bulbs and checked the big plug. Everything looked fine. Reinstalled and only the lights are working. Not sure how to troubleshoot this, I'm fairly new to this generation of truck. Really need a fuel gauge. Found a bad ground out of the tank and replaced it but no luck with the gauge.
Also having trouble with installing the speedo cable. Always looks like it's in but then spins annoyingly immediately when driving. Is there a trick to inserting the square pin? Can't get it to mate inside it seems like.
Thank you for your help and patience with novices like me!
Title: Re: Gauges/ Speedo cable install
Post by: bake74 on February 01, 2014, 09:35:10 pm
http://forum.73-87chevytrucks.com/smforum/index.php?topic=26558.0
http://forum.73-87chevytrucks.com/smforum/index.php?topic=25339.0
     These should get you started.
Post by: bd on February 02, 2014, 01:22:36 pm
Refer to the 1973 Wiring Manual (http://www.73-87chevytrucks.com/techinfo/7387CKMans//Wiring/X_7305_1973_GMC_Truck_Wiring_Manual_CK_10_30_Pgs_Only.pdf).  Verify ignition power (circuit 39) and ground (circuit 150) to the cluster.  Inspect and service the cluster-to-cab ground attachment above the park brake pedal assembly.
While you're at it, verify the most fundamental and overlooked aspect of vehicle wiring:  Make sure all of the cab, engine, and frame grounds are installed, clean and functioning properly...
...Grounds are subject to harsh environments.  They are virtually ignored during routine maintenance.  And, they are easily overlooked when troubleshooting.  Over the years I've heard variations of, "Nah!  They're too simple...."  "Grounds don't have any moving parts!  There's nothing to wear out!"  "A ground couldn't possibly cause all these symptoms!"  "Come on, what could go wrong with a ground!?!"  Yet, they are a common source of headaches on trucks....
Now, is a great time to inspect and service all of the vehicle grounds:  (1) battery-to-engine; (2) battery-to-right frame rail; (3) battery-to-right radiator support; (4) right rear cylinder head-to-firewall; (5) engine-to-left frame rail; (6) dash-to-left kick panel sheetmetal; and (7) rear lamps-to-bed sheetmetal, taped splices, and frame rail....
Which end of the speedo cable are you having trouble reconnecting?  Is the speedo making noise or jumping or...?
