73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: severon on February 02, 2014, 01:08:53 am
Hey guys as the title says I'm building a truck and need some advice but to start here's more about the truck
Its a 1982 GMC high sierra 4x4 was originally a 6.2 diesel and when I purchased the truck it came with a older 350 small block unsure of year I have installed a holley 750 3310-3 vacuum secondary carb with a Mr gasket 1 inch spacer plate with a edelbrock rpm performer air gap 4 inch hi rise intake with headman I believe 1 5/8 to 3 inch outlet long tube headers it has I believe stock 462624 casting number heads with 1.96/1.5 or 2.02/1.6 valves I believe it has the 2.02 valves from running the date code and casting numbers I believe the block is also stock it has gm corporate 10 bolt front end and gm corporate 12 bolt rear end with 3.42 gears a th350 transmission stock torque converter with a older 203 gear driven transfer case with a part time 4x4 kit installed with dual 2 1/4 straight pipe exhaust installed that dumps out behind the rear wheels it has 36x13.50x15 super swamper irons on 15x12 outlaw 2 wheels
Now my question is I am buying a crane cam for 30 bucks with 240 duration and 350 lift with my current setup I'm told I can install this cam without changing my lifters or rockers or valve springs is this true? And is this a good cam for my setup? And what are your thoughts on a trans go shift improver kit?
I am using this truck for street use occasional off road use and very rare light towing and hauling and just fun to drive, I am trying to build a 400 HP 400lb tq 350 small block that has a constant power curve from 1000 rpm to just under 6000 rpm
Thanks in advanced for any advice and input and sorry for the mile long post
You've got some broad goals there. So is this a new cam? Give the specifics on the cam grind. What pistons are in it? Are you planning on rebuilding it or just putting a cam in it?
1) First i hear a lot of good things about the performer rpm air gap and regular performer rpm intakes.
2) i AM NOT an engine person, so i'm just putting out my opinions here:
The cam might be a little iffy as far as driveability----idle and low rpm driving. At the very least you might need a looser converter. If you had a stick you can get away with more cam. This is just my opinion and maybe the cam might be great for the combo.
i too am curious whether you can use a new cam with used lifters?
3) i've driven cars with the b+m shift improver kit---in heavy duty/race mode. Shifts too hard for street in my opinion. If you can get a kit that dials in a more street or street/strip kind of mode i think it would be better.
If that cam is 240 at .050 its much too big for your engine. Most RV cams used with these low compression 350's are not more than about 214-218 @ .050. You may get by with up to about 222 @ .050 (its used in the GM 350/290 hp crate engine), but it won't have the bottom end you need in a heavy truck.
Bruce
To answer some more questions the pistons in the truck are stock I'm running 76cc chambers on my heads and the cam is used it had a break in period before it made 6 passes at the strip I purchased it today for 30 bucks figured worse case I sell it if I can't use it, the cam came out of a stock 350 with stock lifters and valve springs the only numbers I can find on the end of the cam are cch-342-nc than below that it says crane and below that is 4 199 and below that is 11-11-85 from what I can find is a old build sheet with a similar cch# that states the cam is 254/254 lift with 324/324 duration with 108 center lobe line but I do not know if these specs are true. Is this something I could go ahead and install or is this a race only cam? Not to worried about a awesome idle or sound as I am the all around performance
I eventually plan to bore this block to a 355 with forged pistons forged rods steel crank with one piece main and aluminum 215 cc 60cc chamber 2.02 valves heads but I'm having to do all this pieces at a time with a wife and two kids lol
Also Stewart g griffin after doing g some more research trans go offers a shift improver kit specifically designed to tighten up shifting for street use light towing and a longer transmission life guranteeing no slamming when shifting which is only 37.99 I am going to install this weekend will let you know more in a week or two if the weather breaks enough to work on the truck been too cold here in Kansas to do much
hey guys sorry to trouble you again but i found a new cam instead of that big monster racing cam i picked up i am actually trading it for this cam heres the specs let me know what you guys think of it
I am trading for a gm performance cam P/N 24502476
Flat tappet with matching lifters
.435" Int./.460" Exh. lift
212 Int./222 Exh. Duration @.050"
112.5 Lobe Centerline
(Only info i can find online besides what the guy sent me up above)
This hydraulic flat tappet is used on the 350-300 and 330 HP special performance engine P/N 12355345, and 12486014. The duration at lash point in degrees (intake/exhaust) is 320/324; duration at .050" tappet lift (intake/exhaust) is 212/222 and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 435/460. Valve lash is zero/zero and lobe centerline is 112.5 degrees.
What rpm range will this cam give me? Am i gonna be able to run it with stock valve springs in my setup and can it still be used for street, light off road, light towing, and fun cruising?
as good as it sounds, a cam for $30 is iffy. IMO, I would not buy a used cam because there are too many unsee possibilities. it could have a bad lobe, it could be a stock cam, it could be anything. when buying engine parts you need to be careful, see it being pulled out of a running engine proves its good.
I would personnally spend the extra cash to get a new one.
