73-87 Chevy _ GMC Trucks => Performance => Topic started by: scoob4444 on February 12, 2014, 01:40:25 am
How many degrees should my vacuum advance, advance the spark on a 350?
Sent from my XT1080 using Tapatalk
it should be only 20° so lets say you set your timing at 16° your advance should be 36°. now not all advances are the same stock is different than aftermarket and 20° should be stock
You want 36* of advance at 3000 rpm with the vacuum advance disconnected. For stock distributors, this should 16* at idle with the vacuum advance disconnected.
Why thank you
These are some very good papers on timing, ignition etc.:
http://www.digitalcorvettes.com/forums/showthread.php?t=75830
