73-87 Chevy _ GMC Trucks => Interior & Equipment => Topic started by: 75_chevy on February 21, 2014, 04:03:33 pm
Title: dome light install
Post by: 75_chevy on February 21, 2014, 04:03:33 pm
just installed a dome light. pretty simple but I like to show off little projects.
(http://img.tapatalk.com/d/14/02/22/a4ymepe3.jpg)
just marked where I wanted it with a pencil. if you plan on doing this either go an inch below or an inch above where I have marked. where the cab top meets the cab there is a lip that interfered with the light. somewhat.
(http://img.tapatalk.com/d/14/02/22/banapa6a.jpg)
(http://img.tapatalk.com/d/14/02/22/e2atezab.jpg)(http://img.tapatalk.com/d/ 14/02/22/gazene3a.jpg)
first time using a pneumatic grinder
(http://img.tapatalk.com/d/14/02/22/qynepytu.jpg)
(http://img.tapatalk.com/d/14/02/22/ety5a5eb.jpg)(http://img.tapatalk.com/d/14/02/22/5a4eduvy.jpg)(http://img.tapatalk.com/d/14/02/22/any7u4y8.jpg)(http://img.tapatalk.com/d/14/02/22/5e3uqupa.jpg)(http://img.tapatalk.com/d/14/02/22/a9ygagu6.jpg)
Title: Re: dome light install
Post by: 75_chevy on February 21, 2014, 04:05:22 pm
it's not perfect but I was sick of the strips of LEDs all over the place
Post by: bake74 on February 21, 2014, 06:54:14 pm
     It looks good, how big of a pain was it to pull the wire ?
Post by: winky on February 21, 2014, 07:09:26 pm
Looks like he was smart and pushed a wire threw his hole to the bottom. Tied the dome light  wire and pulled it back threw
- I'm Mobile!
Post by: dvdswan on February 21, 2014, 08:54:58 pm
nice job.  great pics for illustration too.   8)
Post by: 75_chevy on February 21, 2014, 09:17:00 pm
thanks guys. yea at first I tried pushing the electrical wire straight down the chute through the cab opening, then did the wire trick. woulda been smoother if the wire wasn't all curled up as there are cab supports in the corner that were hard to squeeze by
Post by: 87_Rado on October 13, 2015, 12:47:34 pm
How did you wire this? I'm currently going to try to i stall a domelight as well but the original wiring was cut. My ctsy lamp still works off the switch
Post by: roundhouse on October 13, 2015, 01:31:29 pm
light gets a hot wire from fusebox and is grounded by the switch to complete circuit
Post by: 87_Rado on October 13, 2015, 02:21:23 pm
Okay so one wire leads to the light, which would be orange coming from the fuse box which is hot. And then where does the ground (white wire) go? Does it go to the switch or what?
