		73-87 Chevy _ GMC Trucks => Performance => Exhaust => Topic started by: winky on March 08, 2014, 12:11:55 pm
				so im ready to get started on my exhaust but i ran into a problem... i had a 208 t case and dual pipes all the way back. wellllllll i started to put them on last week and i realized the passenger side isn't going to work too well lol. my question is how do all of you run your exhaust with the 205? run a stock "U" and just go down the driver side? i have headers installed so that doesn't help clearance and it looks like the exhaust will be close to my front drive shaft as well.
				mines got the pipes ran true dual back let me look tomorrow and ill get back with ya
				ok, thankyou!
				heres some pics of the setup sorry for the poor quality all i have is my phone camera you could run the one pipe below the t case mines just ran beside the t case thats the way i bought it
				thankyou, what trans do you have? i don't think there would be room to run mine next to the case.  and i definitely don't want it under it'll get squashed ;/
				thats how my 205 is set up
				i will try that then lol.
				I have read that trucks with factory dual exhaust used a different cross member, which had a dip to allow more space for the pipe on the other side, but I've never actually seen one.
I also read an article online where a guy modified the cross member to give more clearance for the other pipe.  Its not a hard job if you have a welder, and the actual design is not that critical as long as you get the required clearance and the cross member retains its strength.
Bruce
Bruce
i have seen this cross member which you speak of :D i Had one on my 77.
 th350
