73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: travisr1988 on March 21, 2014, 04:54:30 pm
Title: Head question, best factory heads
Post by: travisr1988 on March 21, 2014, 04:54:30 pm
Ok, so we ran into an issue with my 74cc 882 heads (milled), moisture got in and they may be cracked. My brother found a source to get rebuilt heads for around $400, now he says I can get 882s again or I can use newer TBI heads since we're throwing on the TBI setup anyways, I have TBI heads but they are 58cc 305 heads. So if all heads he can order through this source are $400 and I can choose between TBI heads or 882s or even other late model heads that use either an edelbrock 2101 intake or factory TBI intake from 1991 which heads should I get?
Truck is a '77 short bed step side 1/2 ton street truck, 355cid with a lunati voodoo 10120701 cam (256/262 adv. dur. 213/217 @ 050 .454/.468 lift, 1000-5500rpm).
Title: Re: Head question, best factory heads
Post by: Engineer on March 21, 2014, 09:46:02 pm
Vortec heads from a 1996+ truck. GM Performance Parts has these in the catalog.
I also know the aftermarket sells an intake manifold that uses the TBI on the Vortec heads.
I have considered building a SB 383 for my 1994 K2500 that uses TBI and Vortec heads.
If you are not interested in using the Vortec heads then I recommend the TBI heads that you have. You can probably save some coin by using a factory intake to mate it all up.
Post by: VileZambonie on March 22, 2014, 10:03:37 am
If you go with Vortec heads you can put a tbi adapter on the intake.
Post by: travisr1988 on March 22, 2014, 10:20:54 pm
I have a factory TBI intake, throttle body, wiring, ecm, just need heads. Heads I have are from a 305 and put compression ratio too high for regular unleaded. I would love vortec heads but don't have the coin for another intake manifold. So, the question is which heads do I order, '87-'94 350 TBI heads or 882/similar casting heads?
Post by: VileZambonie on March 26, 2014, 05:06:25 pm
Honestly, they're both garbage heads. They offer no real advantages to the combustion process, do not increase performance, do not increase fuel economy etc. So it sounds like you are going for a stock setup therefore go with stock heads.
Post by: dsgb610 on March 26, 2014, 06:11:28 pm
Vortec heads garbage?
Post by: VileZambonie on March 26, 2014, 06:32:39 pm
Quote
Post by: travisr1988 on March 26, 2014, 10:52:47 pm
Well, we are looking at stock heads simply because we need reliability, low cost, and we're limiting the motor to 5000rpm anyways for reliability. Is there a newer casting head other than vortec that does not require a different intake that would work better?
To put my ordeal into perspective...I don't make much money, I just had a baby 3/15/14, my fiancé is on maternity leave...so unless I can find better heads for $400 I'm limited to stock heads.
Post by: VileZambonie on March 30, 2014, 10:12:22 am
Call Jesse http://www.doverusa.com/products.php
Post by: BADAZ chevy guy on March 30, 2014, 11:37:51 am
This guy has 2 videos that explain the best and worst about chevy heads. This one he talks about vortec heads. Best way to go IMHO. https://www.youtube.com/watch?v=q7UNH0QkxEY&list=UU8XUoWoA03a4-YKEMtUqUbQ
Post by: travisr1988 on March 31, 2014, 12:17:14 am
Guys, I know that vortec heads are the best factory heads, but they don't meet my requirements. Neither of the intakes I have will work with vortecs and I cannot afford to buy another intake. I really appreciate the input but again vortec head are out of the question. Heads must be compatible with either a standard small block Chevy Edelbrock 2101 intake or a factory tbi intake from 1991.
Post by: BADAZ chevy guy on March 31, 2014, 12:59:54 am
A good low end tork head would be the 3998991 casting. It's a truck head with small runners and 76cc chambers, but it's a decent head. a 3987041 head is about the same as the old "Camel Hump" heads of the late 50' to late 60"s 64cc chambers, large runners, develops good mid to high end tork and has the accessory bolt hols on the end of the head. Most have the 1.94/1.50 valves but can be opened up to the 2.02/1.65 valves. Strong casting.
Post by: travisr1988 on March 31, 2014, 01:11:03 pm
If I can get vortecs for less than $500, I found a carb intake for vortec for $150 and I could use a tbi adapter and make a lot more power and torque...the problem is finding ready to run vortec heads for less than $500. Hmmm, maybe I'll just have to push it back further and hold out for vortecs after all.
Post by: BADAZ chevy guy on March 31, 2014, 02:35:54 pm
I've heard of guys getting them out of wrecking yards for $50 - $100 ea. Now that the 96-99 trucks are getting older, you'll probably be seeing more of them in the wrecking yards. Just need to be vigilant. Happy hunting.
Post by: VileZambonie on March 31, 2014, 06:16:55 pm
Call Jesse at the number from the link I posted above, tell him what you're looking for and he'll give you a price. I've had great luck with them over the years. Let him know your budget
Post by: travisr1988 on April 09, 2014, 05:20:41 pm
okay guys, I actually got my tax return that I didn't expect(long story). So I will be going with vortec heads...my brother can get them at 20% off of $299 each. I will be using a JEGS vortec/carb intake with an adapter for the TBI and Lunati Voodoo cam. So that's sorted out, now for exhaust, fuel lines, fuel pump, floor pans, rear tires and tail lights to get it road worthy.
heads are Spartan/ATK
intake: http://www.jegs.com/i/JEGS+Performance+Products/555/513002/10002/-1?CAWELAID=1710856258&CAGPSPN=pla&catargetid=1808722425&cadevice=c&gclid=CImBje6ivb0CFeMF7AodOzYAPA
cam: http://www.lunatipower.com/Product.aspx?id=1982&gid=287
213/219 @.050 256/262 Adv. .454/.468 lift 112LSA 108ICA
Post by: BADAZ chevy guy on April 09, 2014, 06:32:27 pm
Are the heads machined for the higher lift on the cam? Vortec heads will only go .420 to .460 lift.
Post by: travisr1988 on April 14, 2014, 03:35:41 pm
I have a question about the tbi...will i need a tune or does the ecm make necessary changes to accomodate the heads and cam?
Post by: Captkaos on April 15, 2014, 06:55:20 pm
If it is the factory TBI ECM you will need a chip burned for the changes
Post by: travisr1988 on April 16, 2014, 04:37:42 pm
Who knew an engine build could be so frustrating? It was supposed to be a simple build...fix whats broken, change the cam and done. Then my dad decided we're adding tbi...which meant a different cam choice and wiring and new fuel lines and pump. Then when we looked at the old heads we found they need a valve job so he decided i'd buy new heads...350 tbi heads...which i don't think will satisfy me. I talkes to him about it and he told me its tbi heads or smog heads. I want vortecs, since i got my tax return he gave me the okay for vortec heads. So i ordered vortecs...now my brother tells me my dad is mad at me for ordering vortecs and that it'll cost atleast $400 more to use vortecs over tbi heads. I'm tempted to forget about the tbi since what i have is from a 305 and use the quadrajet i already have. Oh and he insists on using egr and vapor canister and all the other ugly smog stuff which of course i would have to buy because my truck has none of it. Yet his truck doesn't have any of it...just a $1600 short block with summit camel hump heads a cam thats too big rpm air gap intake quadrajet and headers (which he is dead set against my truck having because it doesn't need them). My truck is being built to be a daily driver that i can take to meets and run at the strip everyone once in awhile and enjoy...something fun to drive...not something just to drive from point a to point b. It's my hot rod...not his restoration...if i were gonna restore it i would leave the 6 in it and make it 100% stock.
Post by: SomeTexan on April 16, 2014, 05:20:31 pm
If its your truck and your money, do what you want. Personally, I wouldn't even bother with a small block, swap in a 5.3/4l60e. Then you have an easy 300+hp, overdrive and 20+ mpg with a stock 5.3.
