73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: genev on April 07, 2014, 03:36:07 pm
Working on 1979 Chevy C-10, the transmission is dripping at the driveshaft yoke, I have replaced the rear seal, no fluid at the seal, just the drive shaft, how do you repair this.
gene
Welcome to the site, but we need more info. What transmission do you have ? Auto or manual ?
i ran into the same thing on my th350. it dripped more when parked uphill. there is a weep hole that i plugged. i found a diy somewhere online. has cured it since. do a search.
Look here: http://73-87.com/7387garage/drivetrain/yokeleak.htm
Those are the exact instructions I followed. Hopefully this helps you out, OP.
