73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: BackCountry on April 16, 2014, 07:48:45 pm
truck running really rough from 45-50mph. doesn't do it before or after and doesn't feel alignment or tire related. Someone suggested torque converter. does this sound right? any other ideas? At this point 100 is a lot to spend if I'm wrong :-\
1985 k10 with a 305
thanks all
All the u-joints good?
Did it start all of a sudden? Any possibility you threw a wheel weight? Does it change any with brake application? Does the vibration quit if you shift the transmission into neutral and let the engine idle down at 45 - 50 MPH?
not sure about the U-joints but it didn't start all of a sudden, it's been like that since i got the truck about a month and a half ago. I'll check the shift into N and brake application tonight when I get home. (wife uses it to take the kids to school during the day, my commute's too long for a gas guzzler ;D )
And I don't think it's wheel related. I've felt/dealt with that shimmy before and this just doesn't feel like that, but as usual I could be wrong.
As what BD said, it also could be the front rotor's, I have a expedition that did the same thing between 45 - 50 mph only. Could not fix it until I changed out the rotors. The front rotors had warped and for some reason it only had the vibration between those speeds.
good to know. I'll definitely check it out. cause it wouldn't suprise me. but nothing with this truck would at this point lol
when you say rough do you mean a mis or vibration
honestly, it doesn't feel like a 'miss'. but it doesn't feel like vibration either, at least not vibration from tires, but it's very jerky. I guess that's the best way I can describe it.
A frozen u-joint will do that. Add a load in the bed to make the truck squat a bit and see if the vibration goes away.
ok, so I've noticed a couple of things. first, applying the brakes doesn't stop it and it doesn't happen in drive, only overdrive.
Do you feel it in the steering? What's the RPM range of the engine when you feel the 'roughness' at 45-50 MPH? Can you duplicate the roughness in other gears at similar engine RPM?
I feel it all over, it's pretty forceful. like someone grabbing you by the shoulders and shaking lol. but I had it up to 55 in drive and it didn't do it at all. rpm's are hard to say as I don't have a tach, just an ear and it's an auto
