73-87 Chevy _ GMC Trucks => Electrical => Topic started by: rich weyand on April 30, 2014, 05:55:05 pm
Title: Tach wire termination if no tach?
Post by: rich weyand on April 30, 2014, 05:55:05 pm
Does anybody know where the brown tach wire terminates under the dash if you do not have a tach on the truck?
I am buying the combo tach/fuel gauge from these guys, and would like to have some idea of where to look for the other end of that wire. It is there, it comes off the distributor and heads into the cab, I just don't know where it ends up. Yet.
http://www.gmsports.com/content/new-...and-gmc-trucks
Title: Re: Tach wire termination if no tach?
Post by: bake74 on April 30, 2014, 07:42:04 pm
     I am not sure where the actual wire terminates or if it is even there if the truck was not equipped with a tach, but your link you provided does not work, it says "page not found".
Post by: rich weyand on April 30, 2014, 08:07:57 pm
How about this:
http://www.gmsports.com/content/new-tachometer-1973-1986-chevy-and-gmc-trucks
Post by: bd on April 30, 2014, 08:32:05 pm
According to the 1978 Wiring Manual (http://www.73-87chevytrucks.com/techinfo/7387CKMans//Wiring/ST_352_78_1978_Chevrolet_Light_Truck_Wiring_CK_10_30_Only.pdf), page 13, the brown wire (Ckt 121) passes through a firewall grommet and terminates in the 3-terminal connector that plugs directly into the tach board.  The diagram shows the tach circuit as an option, but doesn't show an interim connector between the distributor and the tach.  Neither does the diagram show the tach circuit being used for anything else.  You may just have to trace it out.  Maybe you'll get lucky and it's already there.
Post by: sphinx on April 30, 2014, 09:06:46 pm
From my experience, if the tech was not installed at the factory, the tech harness was not either.  Check the distributor to see if there is wire attach to the TACH terminal, if not you will need the tech harness.  Don't use a plain wire from thru tech terminal, use the tech harness as it has some type of 'filter' capacitor built into it to keep electrical interface from the ignition from reaching the tech.
Post by: Irish_Alley on April 30, 2014, 11:23:45 pm
now here is a question. i have read that you can get a rpm signal off the alt. if this is true would gm run a separate wire from the distributor or just tap off the alt wire?
Post by: rich weyand on May 01, 2014, 01:04:54 am
GM in fact did run a tach wire from the distributor, that connection is part of the distributor cap assembly.  Mine has the brown wire from that connector, but does not have a tach.  It may have before it was rebuilt in the late 90s, but I have a hard time thinking someone would remove the tach if it was already there.
Post by: bake74 on May 01, 2014, 07:41:27 am
How about this:
     That one works, thanks.
Post by: sphinx on May 01, 2014, 10:06:35 pm
Irish-Alley, yes you can get a tech signal off the alternator.  But you got to know the number of poles in your alternator and the pulley ratio between the flywheel and the alternator then set the tech to read that signal.  Every turn of the alternator produces pulses in the voltage out that are converted to the engine rpm.
Post by: Captkaos on May 02, 2014, 12:10:48 pm
I ripped a few of these apart and never found a tach wire.  They were separate.
Post by: sphinx on May 05, 2014, 09:29:52 pm
The tech has to be designed to use the alternator as the input instead of the distributor.  Not the standard GM tech in our trucks.  Sorry if I confused anyone.
Post by: Irish_Alley on May 06, 2014, 11:08:12 pm
i did a little research dakota digital makes a unit to use the alt signal(i was looking at it for the cummins) but you need another tach reading to calibrate it. kind of hard on a cummins but there is a Magnetic Sensor (R8912) that you put near the harmonic balancer and epoxy two magnets on the balancer. it gets its reading and sends the signal to the tach. supposedly its universal  waiting on a email that will confirm this
(http://www.genosgarage.com/images/ISS-R8912.jpg)
Post by: bake74 on May 07, 2014, 07:54:12 pm
      What happens when your magnets collect a bunch of iron dirt and get covered up ?
Post by: Irish_Alley on May 07, 2014, 10:38:34 pm
idk i dont make this stuff lol
Post by: bd on May 07, 2014, 11:06:44 pm
Flying magnet pickups are proven technology.
Rich - did you ever get the answer to your question?
Post by: rich weyand on May 08, 2014, 12:03:11 am
Yeah.  And I replaced the distributor cap/rotor/coil with the Accel parts (8122 and 140013), and realized that what I thought was a (brown) tach wire was an extra loop of the (very dirty pink) ignition wire to the distributor.  So there is no tach wire on mine.
The new tach/fuel combo gauge is on the way from gmsports, though, so it looks like the instrument panel is coming apart (again!) this weekend.
Oh, and I can recommend the Accel parts listed and the Taylor 74206 helical-stainless-steel-core spark plug wires.  Very nice spark now!
Post by: bake74 on May 08, 2014, 07:52:23 am
     Just a curiosity question.  I know Irish does mudding in his truck, though think he meant his new diesel.
Post by: Irish_Alley on May 08, 2014, 10:53:34 pm
yes its for the diesel, if i needed a tach reading for the gasser then i would pull off the distributor instead of making things more complicated.
