73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Brakes and Braking Systems => Topic started by: srodster on May 25, 2014, 12:55:07 pm
Anyone have some photos of their rear axle with the height leveling proportion valve? I have seen the photos from the manual, but would like some up close photos of the linkage to the valve, and the bracket from anyone that has a functional valve. I'm doing a rebuild from a while ago and think I have misplaced some parts. Also, a source for new one would be great too.
I'll attach a photo of the one I have.
Thanks.
More photos to understand better.......
This help, BTW most people bypass this especially if you are going to lift it...
Yah, can I get another one on the left side of the valve to understand where the bracket that holds the rubber line from the pumpkin attaches to? Is it the frame?
(My issue is that I have a k30 suspension with a c20 frame (cc, longbed))
And trying to make sure parts and pieces match up. Don't know why I decided to do this, but I did....., about 18 yrs ago, and now trying to make progress before my Wife leaves me...., ha.
I don't know if I can find one, but why not just eliminate it...
That is certainly an option, but I may need a little coaching on the correct hook-up, and do I have the correct valving left, if it is removed, or do I need a different one........ I have never dealt with that side of it before.
This help? Found it on the net...
First thing I do to every truck I have ever got that still has that is chop it out. Run the brake line directly to the flex hose.
