73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: Dan75k20 on May 26, 2014, 07:37:49 pm
Title: Will these fit a 75 k20
Post by: Dan75k20 on May 26, 2014, 07:37:49 pm
Thinking about a set of this type of wheel fit a 75 k20(http://img.tapatalk.com/d/14/05/27/a2ana3uj.jpg)
Sent from my Nexus 5 using Tapatalk
Title: Re: Will these fit a 75 k20
Post by: zieg85 on May 26, 2014, 08:54:15 pm
http://www.ebay.com/itm/5297-5298-Chevy-GMC-2500-3500-17-Factory-OEM-Wheel-Rim-1-A-/281269986528
Based on the advertised bolt pattern I would say yes
Post by: bake74 on May 27, 2014, 10:37:41 am
     Zieg, that link you gave, if you use "compatibility"  feature on the bottom for a 75 K20, it say's it does not fit.  Though I am not sure how well I trust those things.
"Compatibility
This part is not compatible with 1975 Chevrolet K20."
     But if your bolt pattern is 8x6.5 then it should fit like zieg said.
Post by: Dan75k20 on May 27, 2014, 11:44:38 am
Guy wants 300 for them and I am buying some skinnier tires figure I can get a mpg or so and they will update the look of the truck
Post by: Irish_Alley on May 27, 2014, 11:19:48 pm
you can use up to 2010, in 2011 they changed to 8x80mm on single axle and 8x210mm on dually. this was so they can up the GVW, FAWR, and towing capacity
Post by: zieg85 on May 28, 2014, 05:41:02 am
"Compatibility
Never concern myself with the small stuff.  17" never came in a K20 in 75 and Walmart wouldn't sell you tires because the book says 7.50x16 or 8.75x16.5...  The bolt pattern is what is important
Post by: Dan75k20 on May 29, 2014, 10:06:50 pm
I buy tires from ntwonline.com don't need to worry about Walmart.  Dukes tires in south side  they will install any size that will fit! Good old local tire shop
Post by: jumpkickyergunt on May 30, 2014, 12:48:21 am
Agreed. Check centerbore and backspace.
