73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: dc7432 on June 23, 2014, 05:33:46 pm
Can I remove as one or do I need to pull transfer case off tranny then pull engine and transmission any tricks on removing? Thanks in advance
Depends on how tall your lift will go
And how high off the ground your truck is
If you have enough space under the truck for the trans and t case to tip down and a fork lift it can be done
If
You just have a regular engine hoist it's not gonna work all in one
What he said......I recommend at least dropping the T-case. My buddies tried to pull a whole unit from a 78 Ford Hiboy and busted the transmission because they had too much stuff and not enough room in the engine bay.....and they had a tractor/front end loader
