73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Irish_Alley on July 21, 2014, 03:58:45 pm
(http://i333.photobucket.com/albums/m387/rebel_cowboy_83/Mobile%20Uploads/Truck%20stuff/IMG_20140720_201222339_zps3stlcnuq.jpg) (http://s333.photobucket.com/user/rebel_cowboy_83/media/Mobile%20Uploads/Truck%20stuff/IMG_20140720_201222339_zps3stlcnuq.jpg.html)
this is a picture of a 4.09 ring gear aka 4.10 its for the front
but to figure out the ratio of yours you take the last two sets of numbers 45-11. these are the ring teeth-pinion teeth. you devide the ring by pinion (45/11) and that equals 4.09090909 or 4.10. also if you see on the far right of the ring it says 9 but it really says 456 upside down i dont know why it says this but if your does dont pay no mind to it just the last two sets of numbers
Is this an actual question Irish, or are you just putting this out there for people to search and find? Best and most reliable way to tell is to count the # of teeth on the ring and divide by the count of the # of teeth on the pinion.
No need to look for a number if you have the gears exposed so that you can count the teeth, but the number should still be there.
This is a FYI. When the gears are in the axle I can't never count the pinion. When you tell someone what numbers to divide some need a picture.
The 45-11.
