73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: BidEquation78 on September 06, 2014, 09:55:12 pm
Hi, today I went to a local salvage yard and priced out parts for a manual swap in my 82' C10. The donor truck I found was I believe an 87' C3500 6.2 diesel with a 4 speed(granny gear). I was quoted $75 for everything (flywheel, bell housing,clutch, pedal assembly and all) if I pull it. Anybody have experience on a swap, and if so how much modifying is required? Thanks
The '87 used a hydraulic clutch. Your '82 used mechanical linkage. The firewall will be slightly different and mounting the clutch master cylinder might be kind of difficult.
What engine is in your '82? I don't remember the 6.2L diesel coming with a 4-speed so the flywheel may be a mystery. In any event the 6.2L used a couple of different flywheels on the automatic tranny and neither will work with a gas engine.
If that '87 has mechanical clutch linkage then that is a sure sign that the transmission was swapped in. If the donor truck has mechanical linkage then great, it will adapt to your '82 better.
If the truck has a 4-speed column I would get that too so you don't have the issue of the auto shifter on the column, and 4-speed shifter in the floor....... Unless you like the bubba effect.
I knew a guy back in the day who swapped in a 4-speed. With his old auto column he drove out the pin that held the auto shifter in the column. About half the time when he went to start the truck he would have to put the auto column back into "park" so the starter would work. With the auto shifter missing the column shifter would rotate out of position while he drove.
i swapped my 77. with it being an 87 donor it should have a hydraulic clutch.
You will want to get the bracket that holds the clutch sensor(same as a brake pedal sensor) I cant remember if they are on the same bracket as the brake pedal sensor..
measure the difference in the transmissions i be leave the manual is shorter (may require drive shaft modifications)
as far as install goes..
Cut a Hole in the fire wall for the master cylinder (some trucks already have the hole or a stamped circle)
change out your pedals (just un bolt and bolt in new ones)
measure transmission and see if the cross member is going to rest in the same place (may require drilling new holes in frame)
un do the neutral safety switch on bottom of column and wire it up to the clutch sensor
install master cylinder (make sure to us the 2 rods that come off the pedal "cage" they reinforce the firewall, if you dont use them the fire wall will flex when using clutch and possible crack/break leaving you with a clutch you cant disengage.
Blead your master cylinder and see how you like your new trans
sorry, i have a very busy day so i kinda just jotted this in here, if you need any help or pictures of my setup just pm me or ask here for some and ill do my best to help
EDIT:
Engineer beat me too it lol
Thank you both for the detailed replies! I really appreciate it :D! In response to Engineer, my truck truck is a 350, the donor truck looked to be all original and I was very suprised to see a 6.2 4 speed especially in a 2wd setup... Seems very rare to me! Currently on lunch break so ill post a pic up this evening
Here is the donor I found. It is in fact a 6.2! Such a shame to see it rusting into the ground but all drive-train parts seem extremely solid! Also the price is more than fair.( if you look close enough someone tried removing the 1 ton sway-bar and got about halfway there lol)
Funky lookin box for the heater A/C
Grab that sway bar too
Some hot rodder will want it
I'm planning on going back to the yard(which is 2 hours away) within the next few weeks to get the assembly, so ill take some pics of all the trucks they have!
That 6.2L Diesel will also have a Buick/Olds/Pontiac bellhousing bolt pattern on it. Won't bolt up to a Chevrolet engine. (The bottom bolt on either side will and the dowel pins will line up, but the other 4 bolt holes will not line up)
6.2S had a bop bell housing
You will also need the transmission floor hump. Auto trucks have a low hump and manual and 4x4 trucks had a higher hump.
87s didnt have removable trans humps
I've seen on other sites where people put a NV3500 from a late model Chevy behind the 6.2
How'd they do that if it has the BOP pattern ?
would my best bet be buying a new bell housing? around my area most manual trucks either are automatic, or they have the entire drive train yanked.
Search on Colorado K5.com
I'm not certain the 6.2 has a BOP pattern
Several swap threads on there
I will be sure to check that out roundhouse, thanks :D... Also, what transmission would you guys suggest?(used from a salvage yard of course). preferably 5 or 6 speed but I also don't want to break the bank.
Nv3500. From a 97-07 full size Chevy pickup
Are nv3500 stout enough? I'm working on trading some parts for my friends 388 stroker long block and heard nv3500 tend to scatter past 400lbs..
Several folks using em
Depends on how you treat it
GM put em behind the V-8 in the pickups
Throwing another option in... Picked up 2 doors today from a k30 dump truck at the local scrap yard. He offered me the entire manual linkage setup including everything minus the tranny for $200 pulled. What would be a semi-budget tranny that accepts manual linkage? ($500 and under)The other yard is roughly 120 miles out and im not 100% positive it was hydraulic either...
6.2L Diesels used a Chevrolet bell pattern.
