General Site Info => Welcome => Topic started by: sobitthen on September 07, 2014, 10:56:53 pm
Title: Plow Truck
Post by: sobitthen on September 07, 2014, 10:56:53 pm
Just picked up a plow truck that was assembled from 3 different trucks.
As far as I can tell it has a 1977 K20 frame with 1986 shell.
There is a built 350 with turbo 350 and a NP203 with lockouts.
Assuming GM axles, rear is 14 bolt front 12 bolt, hope he matched ratios.
From the shifter I had thought I had the NP205 and it has the knob from one, but crawled under to find the NP203...
Getting her ready for plowing, headers were rotted out, bout cheapo stainless ebay style, they were slightly larger tube and fit like a glove, all new brakes all around, few bearings in rear, it was a mess in rear, brakes loose 1 side, other side packed with grease, and not just the bearings which is a no-no, the whole darn drum was packed, they had cooked a bearing there once, keyway was beat up, missing thrust washer.
Swapping out water pump for high flow, adding dual batteries, new hoses on plow, high torque starter, all new steering linkages and steering damper, then off to rewire the beast, it is a mess, full of 18 gauge wires running things they shouldn't be, and then to wire up the plow lights...
Anyhow, looks like the right places to find some information if needed an access to parts nearby, chat at you all later...
Title: Re: Plow Truck
Post by: zieg85 on September 08, 2014, 07:06:23 am
Welcome, you've come to the right place
Post by: bake74 on September 08, 2014, 11:41:47 am
     Welcome from California.
Post by: Irish_Alley on September 09, 2014, 10:55:56 pm
welcome from maryland. 12 bolt front, think i only seen dana 44s, 10 bolts and dana 60s
Post by: sobitthen on January 27, 2015, 11:07:32 pm
Ended up rebuilding the TH350 and then replacing the NP203 due to a vibration at highways speeds.
Discovered both lockouts and spider gears in front were bad along with all 4 ball joints. 10F outdoor project.
Started another topic under drivetrain for my new project, installing Vortec heads onto my 880 block, check there for updates to this squarebody American steel machine...
Post by: Tazman on January 28, 2015, 07:22:57 pm
Welcome from AZ.,I remember that when I lived in Illinois. I knew a guy who brought a brand new 79, had a plow put on it and paid for it from plowing the snow in the storm we had in 79.Have fun in the snow.
Post by: srozell on January 29, 2015, 01:22:06 am
Welcome from BC, Canada
Post by: Jason S on January 29, 2015, 06:13:54 pm
Welcome from Kansas!
Post by: illinoisk30 on February 10, 2015, 04:45:57 am
Welcome from Northern Illinois.
