General Site Info => General Discussion => Topic started by: ackland3 on September 11, 2014, 11:56:50 am
Title: Gas tank mounting
Post by: ackland3 on September 11, 2014, 11:56:50 am
My 1985 k10 with the long box currently has one 16 gallon tank and the passenger side has had a hole drilled into it so I want to upgrade to the 20 gallon. Can i do this without moving mounts at all? Would like to know before ordering the parts
Title: Re: Gas tank mounting
Post by: bake74 on September 11, 2014, 06:44:11 pm
     Are you asking if you can remove the 16 gallon and replace it with a 20 on the passenger side ?  Did someone drill a hole into the 16 gallon tank ?
Post by: ackland3 on September 12, 2014, 10:27:15 am
Yes they drilled a hole about an inch inch and a half big in the passenger side and a 20 gallon is about the same price as the 16 so i figured may as well upgrade
Post by: bake74 on September 12, 2014, 09:30:38 pm
     I believe the mounting hardware is all the same, someone will chime in if I am wrong.
Post by: ehjorten on September 15, 2014, 10:59:21 am
Best make sure you have room to install a 20 gal. tank!  I think the limiting factor is clearance to your front spring hanger on the rear leaf springs.
