73-87 Chevy _ GMC Trucks => Interior & Equipment => Topic started by: dc7432 on September 16, 2014, 04:59:52 pm
Title: One speaker not working
Post by: dc7432 on September 16, 2014, 04:59:52 pm
I just installed the following all new wiring and components
Pioneer MVH-X370BT
Front Pioneer TS-A878 3.5 60W 4 ohm
Back 4x10 160 W
10" kicker sub 600W
600W kicker sub
First two days worked well then all speakers stop when I disconnected the front left speaker wires (pioneer 3.5) the other three came on sound great reconnect front left all stop. Any ideas? Short in speaker? Thanks in advance
Title: Re: One speaker not working
Post by: bd on September 16, 2014, 06:06:02 pm
Swap the front speakers side-to-side to see if the problem follows.
Post by: dc7432 on September 16, 2014, 08:11:24 pm
I swap speakers and it works however I get the same thing runs on three but the fourth shuts down the sound when I disconnect the fourth sound comes back sub stays on throughout.
Post by: bd on September 16, 2014, 08:17:00 pm
So, if any three speakers (excluding the sub) are connected the three work; but, if you hook up the fourth, none work?  Recheck all your wiring and connections.
Post by: bake74 on September 17, 2014, 07:18:36 am
     The fourth speaker you are hooking up is either got a problem with the wiring or the speaker itself.  If you switched sides with the problem speaker, and the 3 worked and when you plugged in the 4th speaker to the other side and it shut everything down (like bd suggested) then I would say you have a problem with that speaker.
Post by: dc7432 on September 17, 2014, 05:19:29 pm
The left front wasn't working / shut off the volume when connected. I disconnected the LF speaker wire at the radio and used the wires from the LR radio to the LF speaker and it worked, so not the speaker. I connected the RF speaker with the other set of radio wires and off it went. I will check all the connects thanks for the input.
Post by: dc7432 on September 18, 2014, 03:48:59 pm
Reconnected all wiring no change speakers go out after around 5 minutes could the radio be bad?
Post by: bd on September 18, 2014, 04:02:31 pm
Other than the sub are you powering all speakers directly from the head unit or using an amp?
Post by: jaredts on September 18, 2014, 04:07:22 pm
What impedance speakers are you using?  A better question is whether or not you have checked that they are compatible with your head unit?
Post by: dc7432 on September 18, 2014, 07:05:32 pm
I have a 600 w kicker amp plus the base (600w) and the speakers are connects through the standard wires that come with the radio. The speakers are 4 ohm
Post by: bake74 on September 22, 2014, 08:03:39 am
     Have you tried to leave the left front speaker disconnected to see if it will work for any length of time ?  More than 5 min say.
Post by: frotosride on September 22, 2014, 09:01:31 pm
That channel is grounding out somehow. Pioneer has a built in safety feature that cuts the highs and mids when any of the main  4 channels are grounded. This is to prevent burning up the Moser amplifier. You may have a blown voice coil...or as I have done many a times..your +\- wire is grounding on the dash somewhere.
