General Site Info => Welcome => Topic started by: RipHughes on November 08, 2014, 01:54:08 pm
Title: 1975 Chevy Long Bed in California
Post by: RipHughes on November 08, 2014, 01:54:08 pm
Hello!  Just acquired a 1975 Chevy Long bed in trade for a 2001 Honda Accord I used to have.  Its a working project so hopefully will be very useful to me as I slowly fix it up.  Currently has a strong inline 6 which I am debating keeping or upgrading to a bigger engine.
Previous Owner put a 1982 GMC front clip on it about 10 years ago.  Only real issues that I need to figure is the gas gage and tachometer do not work, hopefully this is a simple fuse problem.  Also apparently the aftermarket radio is draining the battery or the battery itself is not holding its charge.
I am a Novice to this site and a Novice to having a project vehicle so should be allot of hands on learning!
Steven V.
Title: Re: 1975 Chevy Long Bed in California
Post by: zieg85 on November 08, 2014, 11:13:48 pm
Welcome from NW Indiana.  The Tach cluster may have been added on by the previous owner and not wired in.  75 with a 6 cylinder would be rare having a tach but just cause I have never seen one doesn't mean they didn't exist...
Post by: Dr_Snooz on November 09, 2014, 11:20:05 am
1975 is sooooo close being emissions exempt, but not quite there. Think carefully about the smog nazis as you plan your project. You don't want to spend a bundle only to find out you can't register it.
Post by: RipHughes on November 09, 2014, 02:37:32 pm
1975 is smog exempt here in Cali 1976 is the first year they require it.
Post by: RipHughes on November 09, 2014, 02:38:47 pm
Showing just how much of a novice I am,  I meant to say Speedometer.  doh.
Post by: Dr_Snooz on November 30, 2014, 06:13:44 pm
Doh! You're right.
Post by: Captkaos on December 01, 2014, 07:25:37 pm
For the gas gauge check the post on how to test one in the Technical section.
For the speeedo, is the cable connected at the speedo gauge and the transmission?
