73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: tbrown on November 19, 2014, 12:23:15 pm
Title: Problem with tail lights 73 chevy
Post by: tbrown on November 19, 2014, 12:23:15 pm
Both of my turn signal lights on my 73 Chevy blink at the same time. This started after I was working on cleaning up the trailer connections in the back of the truck.  I traced the signal light wires back to the short, 4 prong female plug coming out of the firewall. Both the yellow and green wires going into the plug from behind the firewall flash at the same time when I put the tester on them. I pulled the steering wheel and looked at the white plastic signal switches. The look pretty good, however I have ordered a new signal switch assembly. Does anyone think I am on the right track or could the problem be between the firewall and somewhere else?
Title: Re: Problem with tail lights 73 chevy
Post by: outlaw70nova on November 19, 2014, 12:31:04 pm
My guess is somehow you've tied the green and yellow wires together at the 4 prong connector. If they are touching one will power the other.
Post by: BiggG74 on November 20, 2014, 04:37:18 pm
Isn't there a connection on the bottom of the steering wheel where you could check before you throw a part at it. I believe it's at the base of the column. Connected to your turn signal/horn switch.
Post by: Irish_Alley on November 20, 2014, 11:00:14 pm
im going to go on a limb here and say bad ground at the rear where you were cleaning. since it worked fine before you touched it now its acting funny
Post by: tbrown on November 28, 2014, 08:31:20 pm
Thanks for the three comments. The problem was the green and yellow wires touching within the signal light harness at the base of the steering column.
