		Technical Forum (Read Only) => General Information and Maintenance => Topic started by: Captkaos on November 25, 2014, 10:31:08 am
 Rust areas:
 Battery Tray
 Core support under battery tray
 rear of inner fenders
 front of inner fenders where they meet up to core support
 front of hood (where latch is)
 Cowl area where the firewall meets the cowl (If water is in the floor, this is where it will come in)
 Seam at the firewall
 bottoms of the front fender both front and rear
 bottom of doors
 rocker panels
 front body mount support
 Rear body mount/floor support (Blazer)
 Front floor pans (on Blazer, rear floor pans behind front seat)
 rear b-pillar at the bottom where it meets the floor
 Rear drop off at the bed and floor transition
 inner rear fender lips
 rear gastank hump
 rear of bed
 rear cross sill under bed
 tears at the window opening on the tailgate (Blazer)
 wheel opening on front and rear (lips are bad about holding water and mud if not cleaned)
 Electrical:
 All accessories work:
 radio
 Speakers
 Lights in cluster
 AC fan on all settings
 power windows  (roll them all the way up AND down)
 power locks  (lock them and make sure they lock and unlock)
 dome light
 floor light
 Cigarette lighter
 turn signal lights
 brake lights
 head lights
 Mechanical:
 AC works (blow cold)
 heater works (gets warm
 engine cranks, runs with good pressure (compression test is good telltale)
 brakes (get it up to speed on isolated road and stop in simulated panic)
 Trans shifts correctly (under load, up hill down hill driving down highway)
 transfercase works (do this off of pavement) will it shift in and out of all gear ranges
 Do the hubs work (automatic or manual)
 check ujoints and kingpins for slot
 Tires for bearing slop
 driveshaft joints
 axles for leaks at pinion seal
 back of tire for wheel cylinder leaks
 body damage
