73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: cali6shooter on November 25, 2014, 12:08:38 pm
I have the double barrel verajet 2 rebuilt the head got it all back together after the timing headache and other issues she started but not that epic Rochester is doing me wrong can't find the idle adjustment screw and it will only stay running with my foot idling the engine so any tips to locating the idle screw or air fuel mixter
Do you have a picture or model number of the carb in question?
How do u post pics and model number .....there is numbers and letters all over it
If you have taken the pictures and have them on you computer you can follow this:http://forum.73-87chevytrucks.com/smforum/index.php?topic=6428.0
If you have a smartphone using tapatalk you can upload them
If you have the numbers you can just post them.
have 1980 Chevy c10 with the 4.1l 250 inline 6 I am having issue with idling will start and drive ...timing and spark are good distributor cap and rotor are good and spark plugs and wires are good fuel pump good I took timing gun out to make sure ....it will only run with my foot in it but not to the floor just barely on there somebody said carb jet mite be clogged any ideas I also played with idle screw and air mixture I am stuck it has a 2 barrel Rochester verajet 2 I am stuck [/IMG]](http://) (http://[IMG)
Not sure why you started a new post but have thought about rebuilding it? based on your description I would say it needs to be pulled apart and cleaned out.
