73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: jumpkickyergunt on November 30, 2014, 03:30:59 pm
Title: Looking at 33" or 35" tires. Will they fit on a 2.5" lift?
Post by: jumpkickyergunt on November 30, 2014, 03:30:59 pm
I think the 33's will fit fine, but I wouldn't mind going a little bigger. I have 16x8" rims and I'm looking at 315/75 or 305/70. Would I have to do any other mods with either tire (gearing, etc.)? Its a 79 K10. Thanks.
Title: Re: Looking at 33" or 35" tires. Will they fit on a 2.5" lift?
Post by: fitz on November 30, 2014, 07:30:32 pm
I put a set of 35x12.50R16.5 tires mounted on 16.5" x 9.25" rims on my M1028 (K30) with a 2" lift and they did not clear the front fenders when turning.
Post by: SMiller on December 23, 2014, 08:51:50 pm
Buddy has 2.5in. lift and runs stock steel wheels with hummer tires (36in.) no problems.
Post by: roundhouse on December 23, 2014, 11:30:10 pm
We have 33s on stock rally's
No lift
No rubbing at all
Post by: Hillbillydrums on September 30, 2015, 04:32:22 pm
Stock lift here. No rubbing on 33x12.5 on 15x10 wheels. only a liiitttle when i'm flexing quite a bit with the wheel turned. Even then, not bad. I had 35s and i just rubbed when turning.
Post by: Irish_Alley on September 30, 2015, 04:39:30 pm
read this
http://forum.73-87chevytrucks.com/smforum/index.php?topic=31301.0
i have 33s and 0" lift on my 91 v3500 i rub when wheels are turned and i hit a bump. they also rub on the drag link and wheels maexed turned to the left
Post by: Hillbillydrums on September 30, 2015, 10:48:30 pm
Also, true diameter varies. I.e. a General grabber 35" is a true 35.0". I also had a yohokama geolander mt and its true diameter was 34.4". May not seem like much, but it might be the difference of a little rub on turns or not.
