Technical Forum (Read Only) => Frame, Steering and Suspension => Topic started by: Captkaos on January 10, 2015, 02:01:36 pm
Title: Captkaos' Chopped Crossmember Method (for fast cutting with minimum filling)
Post by: Captkaos on January 10, 2015, 02:01:36 pm
Since I no longer do this except on special occasions (Toolmaster did all the welding), here is the secret to Captkaos' Chopped Crossmembers for quickly marking up a stock crossmember for cutting that allows both pieces to be easily mated back together without a lot of weld filling.  You will need 2 filler plates for the end sections cut to fit inset in the opening.
What you are trying to do on the front is make 3 tape sections with 1.5" tape.  2 and the upper section and 1 at the lower.Make 6 vertical lines front. 1 at the edge where the upper control upright is, another at the "end" of the that straight section one at the bottom 45 degrees off the top and another at the "end" of that piece and then another 45 degrees up to the next section and the last one at the edge of the opposite upper control arm upright.
Then with 2 the 45 degree angles from the bottom one up to the top 2 use 2" tape and set it up to hit the vertical lines.
(http://forum.73-87chevytrucks.com/smforum/index.php?action=dlattach;topic=30043.0;attach=28088;image)
On the back you will have to use the same principle, but it isn't easy to use 45 degrees, you can use 60 degrees but the tape has to be close to 1.3"wide ran at that angle.
The ones below are at 45 degrees using 1.5" and 2" wide tape, and we scribed the bottom with a 1.5" wide curve to allow it to sit down flush
(http://forum.73-87chevytrucks.com/smforum/index.php?action=dlattach;topic=30043.0;attach=28086;image)
If you do it this way it sits right down with no gaps.  ( I always kept the "humps" in mine)
(http://forum.73-87chevytrucks.com/smforum/index.php?action=dlattach;topic=30043.0;attach=28092;image)
(http://forum.73-87chevytrucks.com/smforum/index.php?action=dlattach;topic=30043.0;attach=28090;image)
