73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: empire848 on January 22, 2015, 01:08:16 pm
Hey guys,
I got an 85 Silverado 2wd. with a shot rear end.
was just wondering which years I could possibly swap with?
would really appreciate some feedback.
Thanks.
There is a very broad range as far as years go. If you are wanting a direct bolt in swap, we need a little more info. Is your truck a C10, C20, or C30 (1/2, 3/4, or 1 ton)? Single rear wheel or dually? What gears do you have? 5-lug, 8-lug? Limited-Slip?
Generally most of the 82-87 stayed the same, C10 and C20 rear ends could swap with little work needed
if you go with a c20 or c30 then you will have different lug nuts 5 vs 8. you should have the corporate 10 bolt like said it can be found under 83-87 (maybe 82 idk). ratio would matter only to keep your speedometer right.
Hey guys,
Thanks.
I apologize for the lack of info. it's a c10, 1/2 ton, single, gear ratio 373, 5 lug no limited slip.
No problem, so yeah, any c10 from definitely 83-87 (i think 82 also but not certain) is going to be a direct swap. If you change gears it will affect acceleration, top speed, RPMs@MPH, and your speedometer. A standard GM G80 posi would swap in with no addition if you want.
Any 78-87 with a 10 bolt will swap.
A 73-81 12 bolt will swap also but will require a hybrid u-joint.
im going to have to change my years ;-), i was going off one chart instead of a more reliable business
http://www.ringpinion.com/b2c/DiffList.aspx?SearchMode=Cat&CatID=35&MakeID=3&ModelID=537&Side=Rear&DriveType=RWD
