73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Rear Drivelines, Drive Axles and Gearing => Topic started by: swilliams on February 01, 2015, 01:11:54 am
I have the stock GU2 rear end in my 1986 C10. I need to find out if it has 28 or 30 spline axles. What i have found says it depends on the year but does not go any farther. Thanks
i think up to 87, the axles were 28. (77-87) After 88 they went to 30. But if you get a 30 spline carrier the 30 spline axles from later 10 bolts and 12 bolt trucks can fit.
This is according to Randy's differential book.
They are a top notch shop. i would suggest calling them for help. :
http://www.ringpinion.com/
Thanks for the help
The newer axles from a 88-up C/K 10 bolt are longer than 87 down R/V and C/K 10 bolts.
This is what i am looking at going with Detroit Locker 912A556 Detroit Truetrac Differential. It is for 28 spline axles. I want to be sure i don't have 30 spline.
i'm sorry i meant the 12 bolt 30 spline axles which originally came in a 73-81 truck.
Thanks for the help.
I used a True Trac and it crapped out in just over a year,worm gears inside gave up,but I think they might have upgraded these units.It was on a 89 k1500 with 33x10.50 tires.It made a horrific noise in tight turns
What would be a better choice?
Some 12bolt 30 splines may require some massagine to get them to work, but yest they will go in.
As for a limited slip, it is going to come down to an individuals preference.
I used Eaton Clutch type LSD, I know of people using the newer Truetrack without issues
What is the intended purpose?
I like the Eaton clutch type as well,that is what I replaced the True Trac with and some 7 years later still going,
No problem.
And i wonder if the 88-91 blazers and suburbans had the 30 spline axles?
My purpose is that since i have done some upgrades I spin the one tire. I am thinking that posi will help cut down on the tire spin.
Yes they did...
It could make it spin both, but it should help...
I used a 30spline carrier and axles out of an 88 and up truck in my 10 bolt..If I remember correctly the axles were about 3/8 of an inch longer. I had to go with a Buick Roadmaster drum to accommodate the longer axle.
You might be able to find a good govv-lock out of a mid 80's suburban.Lots of them had it.I'm pretty sure they are the same
I have herd that the gov-lock even though it was stock is not that good. But i am also not building a drag car. I only have but 2 local junkyards and our trucks have always been popular here and parts are scarce. But i do like all the options i am hearing about. Thanks.
As long as you don't constantly beat on it you should be fine. Right now my R10 with the turbos has a Gov-Loc in it... It will be changed soon, but...
