73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: chippy on February 22, 2015, 03:51:36 pm
First post!!!! Hello all..
I have an 86 long bed 2WD. I simply wanted to lower the rear 2 inches to level her out. The swap went fine, but when I took her off the jacks the new shackles rest on the bed.
Talk about disappointed in my skills.. Here is a picture of the finished product. I looked close at the new ones and it didnt appear to be a front or back, no significant bend or bow in the shackle so I dont think they are on backwards.
Any help will be appreciated. Chip
I have read on this before but not 100% sure. You are going to have to c notch the bed support it is hitting. Hand grinder with cutting wheel should do it.
ive always read the same thing. there needs to be a small notch in the bed supports
Here's a picture I found.
What length spring do you have? The shackle should be behind the wheel house
How do I measure the springs?
I had the same problem with those on my 78.I didn't want to notch the bed so I used the lower hole on the shackle and cleanced it for the spring,then cut the top off the shackle .But youl raise it up about a half inch or so
http://www.eatondetroitspring.com/how-to-measure-leaf-springs/
On my 80 short bed i had to notch out the bed as well, it said in the instructions for the kit I bought.
