73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: jeremy.w.eason on March 06, 2015, 02:34:46 am
Got a 76 Chevy long wheel base like to know the wides tire I can run on back without modifying frame the wheel tubs in bed will be made wide. if any one know the back spacing 15" rims help or pictures would be greatly appreciated
15x10 with 5.5 bs. I run 315/60-15 Mickey Thompsons. with no runbbing at all.
Thank you for the info and pics
Generally speaking, with the right backspacing you can run a 14" wide tire in the back
Like to put wides I can in back without cut the frame the bed is
ok
The 14" is without cutting anything. The spring will be in the way before you get to the inner fender..
Cool just need to find the right offset now and I can order my back rims
Thanks for the help
This isn't correct...the tire will hit the wheelwell before the spring as it sits farther outward than the spring by about 1 3/4".
It is just about the width of one space on the bedfloor. Originally when the wheelwell comes down to the floor...it meets a low portion of the bed floor, when moved back in line with the spring edge...it will come down against an upward portion of the bed floor.
Unfortunately my regular computer gave up on me & my laptop doesn't play well with Photobucket so I don't know how to do photos right now.
Attached is from an older post. If you look at my wheelwell & then one of a stock truck, you will see mine is the width of the flat rib closer toward the center than stock. This is where it ends up when widened back in line with the spring edge. http://forum.73-87chevytrucks.com/smforum/index.php?topic=28899.msg241302#msg241302
Here we dicussed the same stuff...in the one picture you can see the wheelwell where it is now in relationship to the U-bolts. Hope this Helps, Lorne http://forum.73-87chevytrucks.com/smforum/index.php?topic=25405.msg211994#msg211994
That's right was going on memory Lorne. New this was discussed, didn't find it though.
Thanks for you help
I moved the spings inboard and tubbed it with 15x14 rally wheels and 9.5 inch backspacing and tubbed it. only costs the price of the wheels and tites ($1000)
I was thinking of doing ladder bar set up with coil-overs on the inside
Thinks for your help
