73-87 Chevy _ GMC Trucks => Electrical => Topic started by: Boxchevrolet on March 29, 2015, 12:42:47 pm
Title: firewall electrical connectors
Post by: Boxchevrolet on March 29, 2015, 12:42:47 pm
hello i am new to the forum and i just bought a 83 chevy k10 350 and i opened the hood and on the driverside firewall where the fuse box is there is connectors that arnt connected to anything, can someone tell me what these connectors go toß
Title: Re: firewall electrical connectors
Post by: Takilma on March 29, 2015, 02:39:47 pm
Some might be for options not installed on your particular rig (?) Why not take a picture and post it here, some of these guys will probably know it exactly.
Post by: Boxchevrolet on March 29, 2015, 06:16:53 pm
heres a picture
Post by: LTZ C20 on March 29, 2015, 06:43:17 pm
Do you have a wiper motor/washer pump installed? The 2 in your hand look to be for the wiper motor and washer pump, they should be 1 unit with 2 plugs.
Post by: Boxchevrolet on March 29, 2015, 07:13:15 pm
idk if they are installed, there is nothing near them for them to plug in to. could you put a picture of what they are support to go to?
Post by: LTZ C20 on March 29, 2015, 08:19:08 pm
The plastic square box that has all the wiring going into it is the firewall fuse box harness, the washer pump/wiper motor should be directly above it, between the brake booster and inner fender. I don't have a pic on my phone.
Post by: Boxchevrolet on March 29, 2015, 09:48:29 pm
thankyou apparently the truck doesn't have a windshield wiper motor , now on another note when i turn on my headlights the fuel guage move to below E, otherwise it shows the correct amount of fuel, do you have any idea what could be causing that?
Post by: LTZ C20 on March 30, 2015, 01:08:26 am
Here is the wiper motor and plugs, there are 3. These should clear things up for you.
(http://tapatalk.imageshack.com/v2/15/03/29/125433227d03783e627e5fa56a6310c1.jpg)
(http://tapatalk.imageshack.com/v2/15/03/29/83d21a6c2787aca27623b202853bceae.jpg)
(http://tapatalk.imageshack.com/v2/15/03/29/3b470017b739f9da1c5784aeb3257040.jpg)
As for your headlight question, I'de say best check the grounds first.
Post by: Boxchevrolet on March 30, 2015, 07:56:19 pm
thanks man
Post by: LTZ C20 on March 30, 2015, 10:46:59 pm
Welcome.
