73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: a.graham52 on April 28, 2015, 08:58:32 pm
I have a 77 c10. I checked the glove box but can't find the rpo sticker. Any other methods for locating rpos?
If its not in the glovebox it might be on the inner fender. If neither of those spots have it.. then its gone.
Build sheets may be in the seat springs. My 76 had a replacement seat with the build sheet from the donor truck tho...
Seriously? Lol. Just look in the springs for a loose paper?
Build sheet != RPO code list.
No build sheet under the seat :\
All of the places mentioned by the previous members are correct. I have a 1977 Chevy K30 DRW and the build sheet was in between the gas tank strap and gas tank. I couldn't believe it! I pulled back the bed to do some sending unit work and there it was. It was not perfect but seeing how it was from Nevada it wasn't in to bad of shape. You could also check inside the door panels and on top of the headliner. Not normally a place for them but who knows?
Why would build sheets end up like that. Jw
Not really sure, they must have forgot or maybe it was a Monday.
