73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: billyt33 on June 17, 2015, 01:50:59 pm
Title: np241 rebuild questions
Post by: billyt33 on June 17, 2015, 01:50:59 pm
I just bought a passenger drop np214 out of 90 blazer and I need to rebuild it.  Its been sitting out for a long time so I assume it needs a rebuild.  I got it for an ls swap so i could use a 4l60e.  My question is how hard is it to rebuild?  I've never rebuilt one and I'm not sure how difficult it would be.  Would I just be better off getting it professionally done or is it easy enough to do yourself?  Thanks guys
Title: Re: np241 rebuild questions
Post by: Irish_Alley on June 17, 2015, 01:57:52 pm
http://www.cumminsforum.com/forum/94-98-drivetrain-except-engine/443740-np241-dld-rebuild-w-pics.html
its a drivers side drop but should be the same ideal
Post by: fitz on June 19, 2015, 12:08:00 pm
Any guesses on how much it would cost to have a tranny shop rebuild it?
Post by: roundhouse on June 20, 2015, 07:34:59 am
If the fluid looks good I doubt it needs rebuilding
Unless it was in a truck owned by a redneck or teenager
Lock it in 4 hi and spin the input shaft with one hand with your other hand on the output shaft
See if it spins smooth with no bumps
And hold one and rock the other shaft back and forth to check the slack in the chain
Do the same in 4 lo
And also spin it in 2 hi
If the fluid is clean and everything spins freely and there is little or no slop in the chain I'd install it and run it
They are easy to install and remove
Post by: billyt33 on June 28, 2015, 07:11:09 pm
Thanks i had a guy look at it and it's in pretty good shape.  Changed the seals and stuff.  Should work perfect.  Thanks guys
