73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: Chuck Step-a-side on July 14, 2015, 08:59:46 am
Has anybody have or had water leaking into the cab of 1984 Silverado Stepside from the cowl area where the rubber gasket is for the hood hinge? How can I stop the water from leaking there? Thanks, Chuck
Yes its a common problem. Remove the cowl panel and look for the seam sealer coated seam. Missing seam sealer and/or rust holes will cause water to leak into the cab.
Do you know if those rubber seals for the hinges available? Thank you, Chuck
It is available--I bought one not too long ago for my truck but forget where I got it. Try Chris on this site first--he can tell you where to get it if he doesn't carry it. It won't help your cab leak though.
Thank you Jaredts.
