73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: farris on April 27, 2004, 11:41:00 am
Title: Removing Front Fender 1980 C10
Post by: farris on April 27, 2004, 11:41:00 am
Does anyone have a link or detailed instuctions on removing a front fender on a 1980 C10?
Title: Re: Removing Front Fender 1980 C10
Post by: roundedline on April 27, 2004, 03:54:00 pm
remove the 12 or so bolts holding the inner fender to the fender, remove the 13 or so bolts holding the core support to the fender and the front latch sill to the fender (requires removing the grille) remove the 2 or 3 bolts holding the grille valence/core support to the fender, remove the 3 bolts holding the hood spring/hinge from the fender, remove the 1 bolt on the cowl, the 1 bolt in the door sill and 1 bolt under the cab at the bottom rear of the fender.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
