73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: jhbeat on September 01, 2004, 05:12:00 am
Title: full side glass
Post by: jhbeat on September 01, 2004, 05:12:00 am
hello people, first time here.glad i found it...... anyway i have a 78 half-ton step side with 86 frame and front-end. I've been working on for a while now and i'm ready for paint, i removed all glass and i really like the way the doors look without the wing windows, really clean look, it flows with my shaved doors.
Has anybody performed this modification before? or heard of it? from what i see i need to get full door glass from a 89 truck thats the closest i think that would fit. but can it be cut to fit? just a thought i would like to put together if anyone can help, i would be very thankfull:rollin
Title: Re: full side glass
Post by: roundedline on September 01, 2004, 10:10:00 am
No one makes glass to fit and you can't cut the side glass on a truck as it is tempered.  From what I remember when I was looking, the curve on the 88-99 was different, and wasn't shaped right to fit the hole.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Post by: 78rustbucket on September 04, 2004, 03:02:00 am
seen a how-to in a magazine years ago n im sure it was for the 73 up trucks. if i recall it rite it only showed the install n the glass was custom made laminated stuff. i imagine its not cheap once u find a glass shop thats able to do it
Post by: jhbeat on September 04, 2004, 06:00:00 am
thanks for the input guys...I been looking for my old truckin mags but still no luck, think ex-wife trashed them!
i thought if i found an oversized glass i could have it cut but i guess not. I'll just do with those ugly wing windows for now..thanks again fellow truck lovers!
Post by: bigblock73 on September 14, 2004, 12:21:00 pm
Chris, did you give up on your adventure/research with this?
...Jeff
'73 swb 2wd
'77 Blazer 2wd
73-87.com
Post by: roundedline on September 14, 2004, 07:04:00 pm
no Jeff I haven't.  Things came up as you know, so...
Project Su
Jimmy 2WD Project
Post by: 87layinlow on September 21, 2004, 09:23:00 am
I know that I replaced my back-right window in my 93 ford explorer with plexi and it worked out great. I spent 17$ on the entire setup. Plexi and caluk and clear duct tape and black paint. Keep in mind this is the rear quarter panel glass, a big window.
I simply traces the opened in carboard, cut it out, traced it on plexi, useda  2$ plexi/plastic cutter razer, snapped it, used likea 8$ dremil and my hand to smooth the edges, layed the caulk, put the window in place, and duct taped it. 2 days later i removed the duct tape a,d used some like 1 or 2$ pin stripe tape to make an inner border like most suv windows have and taped it off a little and sprayed it in black. at day and night time when its not wet you have no idea its not the stock window. it looks perfect.
My idea?
A truck has 4 main windows but only three really play a role unless you chop top. The two doors and the rear window. Now you can get plexi, lexan, cool blue etc in tinted colors like a light black tint etc...
So... why not attempt to make one window... and if it doesnt work then all you wasted is like 20$... but make one window for a door and see if its possible to make them from one of these materials.  It would take quite a long time for one of these to fade, which is the only problem i can think of that someone might say, and i know you say "but the glass has a small bend in it" well its not that mich of a bend if any, and you can use the stock glass to help... lay the plexi over the stock and LIGHTLY heat it up using like a heat gun.
Thats just my idea of how you could do it.. if it worked then do the other door and rear glass by making it a solid one piece.
