73-87 Chevy _ GMC Trucks => Electrical => Topic started by: jumpkickyergunt on October 11, 2015, 04:37:00 pm
Is there a pastey copper material or something that will fix a crack in my cluster PCB? It's right next to where the bulb inserts near the top of the fuel gauge. As of right now there is a voltage drop shown in the gas gauge whenever the lights are turned on or the turn signal clicks on. If I put a screwdriver across the cracked part everything appears to go back to normal.
You can solder a repair with a jumper wire or use a printed circuit repair kit.
Could try one of those defroster line repair kits.
Just don't use one that has resistance
i know at my napa and autozone they stopped carrying the defroster repair kit
