73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: philo_beddoe on October 22, 2015, 08:14:32 pm
Has anyone ever used those alternate antennas, small black box with a stick up side and requires a 12 volt connection? I sure hope they work. I hate the windshield antenna.
I just put the 89-91 style through the top of the fender
You mean the shark fin looking ones from newer cars? I know people that have put them on older cars and they work well
No, this is it.
(http://images.tapatalk-cdn.com/15/10/25/dda79af590616b80a04f05ced03d478b.jpg)
Well, i hooked up the antenna, i couldnt believe it!! Every station crystal clear, and you'd never even know the antenna was there! Plus with my mew modern in-dash mono speaker (witch is a bit of an upgrade from the 70's) sounds like i have a Bose system! Well, almost. At least no more stupid windshield antenna.
Philo, how much do they cost and are they available any place like Auto Zone or NAPA?
Greg
Why do you hate the windshield antenna?
It looked kind of ugly coming out of the dash right where it connects at the base of the window. Plus poor reception, i need a little more power where i live, very rural.
Hey philo, did you pick that up at ? I have seen them advertised but didn't know how good they were.
Yes, most of the online catalog companies have them. I think I got mine from brotherstrucks.com. Also, classicparts.com has them. (I think brothers was slightly cheaper) I have not seen them in local retail stores. avg. price. $39.99
I had several of these trucks when I was younger. As long as the connection at the base of the windshield was good reception was fine. Very rural central NY state... Northern Chenango county Sherburne, New Berlin, Norwich area. Schenectady, Utica, Binghampton, and Syracuse AM stations came in fine.
From orbit on my Android.
Now that i think of it, my reception problem started when i went back to the original 1977 radio. Those original radios dont have much power i guess. But the new antenna IS much better. Oh well..
....and so I thought. Why do stations come in clearer with the engine off. When parked and the key turned back, they come in clear as can be. Maybe i'll get a new retro style radio all together. Almost at wits end.
Interference from ignition and charging systems on the truck. I believe they make a anti static box you can plug into the radio to reduce said background "noise" or at least they used too
Sent from my LGL34C using Tapatalk
Why did the cheap aftermarket radio that was in there seem to have much more power and reception?
Most modern electronics have built in suppresors to handle the noise from the ignition. And someone correct me if I am wrong but the plugs that are originally supposed to be in it are shielded, most of the plugs now are non shielded cause the electronics use suppressors now
...someone correct me if I am wrong but the plugs that are originally supposed to be in it are shielded, most of the plugs now are non shielded cause the electronics use suppressors now
Automotive spark plugs are not shielded. They possess a resistor core that limits discharge current. Resistor core spark plugs are still very much in use and cost effective for suppressing RF interference.
In contrast, shielded spark plugs possess a full metallic encasement that encloses the wire and spark plug from the source to destination.
Ok, so if the salesman in 1977 was showing a truck and you test drove it and wanted to hear the am radio and lived in a rural area, what would you hear, static? Not a good selling feature? So car radios didnt work in the 60's and 70's?? Why is my wifes 2014 nissan radio sound crystal clear? Will getting one of those retro looking modern radios solve my problem?
Right, knew I was using the wrong word, and I guess I am wrong with the use of resister and non resister plugs too. The non resistive plugs must be the ones harder to find now. The shielded were pretty common on military waterproof systems, I should have known that, just got new plugs for my m35
Either way technology has changed so much, that original radio probably sounded pretty good in 1977. But another possibility is some of the internal "parts" may be degraded some from age, that and analog radios are pretty hard to tune, I can remember playing with the tuning knob going to town in my parents vw just so the station would play clear
Well that makes a little more sense, i will get a modern retro looking radio and try that. Modern radio, speaker and antenna. If that dont work then its a bluetooth speaker and my iphone! That'll learn it!!
bd is absolutely correct. Again.
The first thing you want to check is to insure your radio chassis has a solid ground to the body of the truck. The mounting bracket on the back of the radio if present should do assuming there is clean metal to metal contact at the radio and dash.
Don't rely only on the black ground wire of the power harness. If your radio is only grounded using the black wire a ground loop is possible which will lead to the problems you describe.
Second make sure you have resistor spark plugs. Normally there will be a "R" in the part number.
Don't throw the baby (radio) out with the bathwater unless you want to throw it my way. I need a period correct Delco for my truck.
I have no grounding whatsoever. Will ground first thing in the morning and post results immediately. Good thing, was about to put a bullet through the center of it.
Your radio is grounded otherwise it wouldn't work.
What you want to look for first is a metal bracket that is connected to the back or right rear side of the radio and is bolted to the underside of the dash.
I installed, there is no metal bracket. So how shall i ground. The metal frame of radio to metal dash?
You are going to want some sort of support for the radio. Find a OEM bracket at the junk yard or fab one.
Relying only on the shafts is bad. They will fail and they don't offer an ideal ground.
If you want to test the ground loop theory make a solid ground connection with heavy gauge stranded wire or better yet a braided ground strap like the one you should have running from the engine block to the firewall.
http://www.summitracing.com/parts/aaf-all76330?seid=srese1&gclid=CPKLoMHyiMkCFQkyaQodwe0KuQ (http://www.summitracing.com/parts/aaf-all76330?seid=srese1&gclid=CPKLoMHyiMkCFQkyaQodwe0KuQ)
(http://static.summitracing.com/global/images/prod/mediumlarge/aaf-all76330_ml.jpg)
I would also plug the windshield antenna back into the radio to eliminate the possibility that your powered antenna is not the cause of the ignition noise.
I am aware of the support the radio needs so i used a heavy duty spring from the back of the radio to somewhere on the dash, it is holding firm--no play or movement. I will get going on the ground and try the windshield antenna again. Standby....
Well i grounded radio frame, which didnt help with that antenna. So i hooked up the original window antenna and there was a huge difference. Even with the vehicle running stations were very clear. However, this piece came off the end of the window antenna, so i carefully inserted the coaxial wire into back of radio and was able to make connection. How in the world do i replace this. I am NOT removing my newly installed dash pad!(http://images.tapatalk-cdn.com/15/11/11/d406c087f5127d502084901b08c10571.jpg)
http://www.vetco.net/catalog/product_info.php?products_id=8818 (http://www.vetco.net/catalog/product_info.php?products_id=8818)
(http://www.vetco.net/catalog/images/VAN-MP3X.jpg)
Get a new antenna cable.
It honestly sounds like you are really trying to chase around a bunch of stuff have no idea how electronics work. Anytime you get ANY interference through the radio you have bad grounds somewhere. A good example of this is when you turn your radio on and rev the engine and you can hear a whine through the speakers.
The battery, alternator, engine, cab and radio all need a GOOD solid ground. Radios are also not made the same and will use different materials INSIDE that can really determine the quality of a radios.
If you are not using star washers and bare metal when doing grounds things will never run properly and regarding the end you found just run a new coax cable for the antenna.
Well, i dont hear any whining nor do i hear the wipers through the radio either. I remember some cars you could hear the wipers going back and fourth. I will get a new cable, just not sure how it attaches at the base of the windshield.
Need one of these: http://thumbs1.ebaystatic.com/d/l225/m/m2GAlFcWTHWYBfI2Ka9icFQ.jpg
Modern day spark plugs have resistors there should not be any feedback at all from stuff like that.
I've been told by a guy who worked at railroad bazzar for a long time installing steteo systems professionally to keep my ground wires away from the positive wires if possible, that I could use a good, larger gauge, well shielded wire and to try to keep any stereo/amplifier body grounds shorter than 8 inches long to prevent interference from ignition sources. I'm not sure about it's effectiveness. But I figured it's worth mentioning.
Actually i think i found what i need. I'm connected fine at the base of the winshield, but this section is what i need:
(http://images.tapatalk-cdn.com/15/11/12/9b0f78b04a58f81ef910fdb8aa49894b.jpg)
