73-87 Chevy _ GMC Trucks => Electrical => Topic started by: bigge31566 on November 19, 2015, 11:54:48 am
Im rewiring 1983 C10 truck and kit calls for wire to battery power , one to ignition accy. one to nuetral safety switch, problem they dont tell you which is which, and there are 9 different blade terminals on steering column. is there a drawing what each blade terminal does
I would like the answer to this post as well...
1983 Wiring Manual (http://www.73-87chevytrucks.com/techinfo/7387CKMans//Wiring/ST386_83_1983_GM_Wiring_Manual_CK_P_G_10_to_30_and_ST.pdf) page 10, top center - schematic illustration of ignition switch connector from the perspective of the connector face (female side). The ignition switch is outlined directly below it. Wires are labeled with metric wire size, wire color, and circuit number.
