73-87 Chevy _ GMC Trucks => Electrical => Topic started by: bigge31566 on November 21, 2015, 01:09:20 pm
Title: Wiper motor wiring
Post by: bigge31566 on November 21, 2015, 01:09:20 pm
Im rewiring my 1983 c10 intermitt. wiper motor and have a few questions, Ive located all the wires pink 94, ppl 92, blk 150, blk/blu 97, and the gray 91, the only thing that Im not sure of is white 93, would this be the power to run motor and washer
Title: Re: Wiper motor wiring
Post by: bd on November 21, 2015, 01:42:03 pm
Correct.  It comes directly off of the wiper fuse.
Post by: bigge31566 on November 22, 2015, 07:49:22 am
My kwikwire kit is suppling power to the wiper switch, do you split off of this wire and catch washer sol., and the wiper motor, since not using old fuse block
Post by: bd on November 23, 2015, 10:11:23 pm
Did your kit come with instructions and tips?
The OEM didn't supply power to the wiper switch.  Power fed directly to the wiper motor and w/washer.  The dash switch just controlled the ground connection.  Are you sure that what you think is power to the switch isn't just the ungrounded return from the wiper motor?
Post by: hatzie on December 03, 2015, 10:09:32 am
I explained how the stock wiper switch and motor are wired in this thread.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32195.0 (http://forum.73-87chevytrucks.com/smforum/index.php?topic=32195.0)
