		73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Stewart G Griffin on December 16, 2015, 06:50:39 am
				Just curious, does the in-tank fuel filter/(sock filter?) ever need to be changed?
				i never heard of them being the problem but most times if someone drops the tank to replace the sock then they will be replacing the fuel pump and sock/strainer. that being said if you want a valid warranty with the electric fuel pumps then you have to replace the sock/strainer or it will void the warranty
				The intake sock filter is only changed when the sending unit or sending unit/fuel pump combo are changed. I believe the warranties on these replacement units are void if the sock is removed.
				some sending units you can just replace the pump for $40 or replace the sending unit for $185
 http://www.autozone.com/external-engine/fuel-pump/premium-fuel-fuel-pump/chevrolet/c1500-1-2-ton-p-u-2wd/1994/6-cylinders-z-4-3l-tbi/563477_478947_6210/?checkfit=true
 and this is in the notes
 "Notes:   Electric
 Failure to install a new fuel strainer (where applicable) will void warranty"
