73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: bcstingray on January 31, 2016, 05:11:00 pm
I'm getting ready to swap my six cylinder with a V8. Can anyone tell me if the throttle cable will have to be changed?
v-6 or straight 6?
Straight 6.
i see different part numbers listed for each the straight six and v-8's. Maybe try yours first and if it doesn't work, then you can get a new one.
i know with my 8 to v-6 swap you could use a v-8 cable for the six and possibly the 6 to 8, but i ended up using the correct cable for the 6 because i accidentally broke the plastic tab at the accelerator end on the 8 cable.
One good thing in your case is that v-8 cables are so easy to find by so many sources. Top quality stock and aftermarket. The same can't be said about v-6 cables.
This webpage might be helpful:
http://rmcavoy.freeshell.org/6to8.html
The cable for the 8 is much shorter, depending on the year the end may be different, I have one for an 1985 , will never need it.
I haven"t removed the six yet. I was hoping to have it sold before I made my swap. I would be interested in your cable just in case the six one doesn't work.
