73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: JoshsC10 on March 30, 2016, 11:49:36 am
I ordered some hooker full length headers and the passenger side would not fit, I'm sending them back and looking at a set from headman they say their for my year but I am afraid I'm going to run into the same problem?? Any advice would be greatly appreciated. 83 c10 shortbed
So why didn't they fit? Did you remove the starter?
Yes I removed the starter but I would of had to re route my exhaust around the crossmember
And I was looking for something that would of fit without any issues? I also have a bell tech 4/6 lowering kit and they were going to rub on the ground if I hit a bump. I have some no name long tube headers on it but there just really old and not in good shape.
small block or big block?
Small block
They have been making headers for these applications for so long I am surprised you can still buy a set with fitment issues for sbc applications.
this thread might be helpful. i dont think they make headers that are a direct bolt in over the crossmember long tube design
http://67-72chevytrucks.com/vboard/showthread.php?t=701985
Back in the day everyone had custom headers. Hammer bangs up an down em'.......lol
I have Headman Headers on my build. They fit perfect. I had to move the gas lines and a brake line on the passenger side. I was able to put the passenger side on from above and the drivers side from below after removing 2 spark plugs. I have a double hump on my trans cross member (one hump on each side). My headers lined up with the humps pointing under the cross member.
what part number do you have?
I bought Headman part #69090. They ave the ball and socket type collector. I have Sportsman II heads with angle plugs and this is what I had to have. If you don't have angle plugs, you might be able to use another part number. I bought mine from Summit Racing.
Contact Summit and ask them a question and they'll email back with the info on the headers for your build.
I wound up welding my old headers where they broke and I'm going to have them coated. Thanks for all the help.
I have an 87 r10 305tbi 700r4. Long tube headers will hit every time. You need to get a set of headman mid-length headers and you won't have any problems. They have them in paint or ceramic coated.
