Here's some paint questions I have- if I'm going to repaint the door panels the same color, is it necessary to use the prep? Or, can I wash them with soap and water, swab em down with alcohol, then paint them? After paint, should the door panels be finished with clearcoat? AND, finally, should the paint be completely dry before clearcoat?
You need to follow the instruction in the other post. You don't want to clearcoat the panels.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
