73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: zliss4398 on May 15, 2016, 09:00:05 pm
Title: Edelbrock 1406 carb won't stay running
Post by: zliss4398 on May 15, 2016, 09:00:05 pm
I just replaced the carb on my 1986 Chevy k20 from an Edelbrock 1910 to a 1406. I went to start the truck and it won't stay running. It will start but shut off after 5-10 seconds of running. PLEASE HELP!!!
Zach --- 1986 Chevy K20
Title: Re: Edelbrock 1406 carb won't stay running
Post by: Rattler12 on May 15, 2016, 09:38:06 pm
Junk and chunk it.....it's what an edelbrock does
Post by: rich weyand on May 15, 2016, 10:05:06 pm
Is the choke plate open or closed?
Did you adjust the idle mixture screws?
Did you advance the idle throttle screw?
Did you advance the fast idle throttle screw?
Post by: VileZambonie on May 16, 2016, 07:32:13 am
and did you hook up the brake booster or at least plug the port in the back of the carburetor? check for vacuum leaks?
Post by: Stewart G Griffin on May 16, 2016, 04:52:38 pm
And, is it a new carb or has it been sitting on the shelf for a while?
Post by: zliss4398 on May 17, 2016, 07:05:04 am
I didn't touch the adjustment screws and yes the brake booster is hooked up in the back.
Could it just need to be adjusted?
Post by: blazer74 on May 17, 2016, 10:28:08 am
So, why did you replace it.
What was the problem with the other carb?
Post by: rich weyand on May 17, 2016, 04:10:18 pm
What makes you think you can just drop a carb on a vehicle and not adjust it per the instructions?
Post by: Irish_Alley on May 18, 2016, 07:09:00 am
to add more to the questions.
electric or manual fuel pump? hows the fuel filter?
not familiar with the floats on the edel but are they adjusted right?
